802MS3
So this is probably a dumb question. What is the correct way to adjust the KW coilover rear height? Are you supposed to just start cranking away on the middle of the spring seat with the 10mm Allen key? Or should you loosen the 3 5mm bolts around the big one first?
I tried doing both and it doesn’t want to turn. I ended up shifting the seat a bit and made it off center
I’ve had these on for about a year and a half so it might be frozen up. I know this is dumb question but the German instructions weren’t of much help. Thanks for any help guys.
