lean at wot
CounterKilla
Hey it's me, back again. I fixed my issue by buying an oem maf sensor. Car is pulling VERY well and feels fine. Im currently on the versantune 93 base map for a downpipe. I did some logs just to be sure everything is good and this is what i see. 13s at wot... a little bit of knock at the end too. It begins to taper into the 11s where it should but before that is what im worried about.
https://www.revisionsrus.com/logs/1337
The log shows you not going WOT, you need to keep the pedal all the way to the floor for a full wot log. STFT and LTFT are doing their job as you are not going actual WOT. App would be 99, throttle would be 76 if you were actually WOT. To get a good log you will want to put the gas all the way to the floor at 2800 rpm and hold it there until at least 6500 unless it starts bucking or cutting out.
