Hey everyone!
Im having some issues about my mazdaspeed. Im have really slow spool with my current turbo: BNR S1 Only hitting ish 10 psi at 4000 RPM. Peak boost is 14,5 that about the spring pressure that is hitting. I did a smoke test on pressure so i thought it would be about the same as a boost leak? Everything was tight and i have not seen any smoke coming from anywhere. Never had any problems with my k04 setup hitting 18-19 psi. Now with a bnr s1 and 3 port and having the problems.
My mod setup: Bnr s1, Streetunit tmic, Damond occ, Muffler delete, Catless downpipe, Cobb bcs, Gfb bov, Japspeed tip, Corksport Sri, 2nd cat removed and Autotech hpfp. I have ran different setups of boost control, different setups without 3 port and not getting it work. Max boost is now 14,5 psi with 40% wastegate duty cycle.
