Was hoping someone has some insight into my issue. I removed my injectors to have them cleaned. I installed the injectors following the exact specification in the shop manual. After I was done I Immediately ran a compression test to check the seal. For some reason I'm only hitting about 50 psi per cylinder. Before I removed the injectors I was a solid 180 psi across the board. Do I have to run the car to set the injectors or something? I though they should seal right after I was done but maybe I'm wrong.
