JamietoddUK
Hi all,
New member of this forum, have been an MPS OC member for a couple years in the UK now and have a fully bolted BNR4 mk1.
So in September last year I got an issue with low fuel pressure, sitting at 40-60PSI on idle and pushing to 100PSI when trying to drive - the car is undrivable at the moment, zero power and very stutter, however it will sit and idle all day with no hiccups at 50 ish psi. I also had a code P0091 which is "fuel pressure regulator control circuit low voltage", but somehow this has now disappeared but the symptoms have not. So far I have tried -
Swapping whole HPFP with another club member
Relief valve (twice just on the off chance that I bought a 2nd hand one that was also ruined)
fuel pressure sensor
In-tank fuel pump which contains the regulator its self
Any other ideas? it has been off the road since September and im forgetting what its like to drive!
