The_big_dill
Hey guys,
Wiring in some subs using the OEM amp outputs to the speakers as a source for an LOC.
Been having issues with audio performance and I narrowed it down to the LOC. I should have probed the wires coming out of the amp to understand that they are low level outputs, so I am going to wire them directly to my amp.
Question is: If you have done this install, Which pins did you use off the factory amp to your aftermarket amp?
Terminals B/C output 0-8V AC
Whereas the speaker inputs are 0-1.5V AC.
