These cars don't have torque steer. They break traction. If you have problems that you think are torque steer you have broken or worn parts in the suspension or need better tires or a better alignment.
I had no torque steer for 110,000 miles then started getting some ended up being a bad sway bar end link
what torque steer? just hold the wheel heh.
rear motor mount is your biggest upgrade if not already done so, followed by rear sway bar recommend white line, OEM end links still seems to rein supreme unless you need adjustable then white line. for motor mounts I recommend damond Motorsports
front sway bar isn't all that common of an upgrade from what I've seen over the years unless folks are setting up for the track.
Regarding the OEM end links are you referring to the rear to go with the white line rear away bar and or OEM for the front sway?
not sure what's so complicated about my post... end links stay OEM unless you need adjustable ones and then you go with white line. irrespective of if you an upgraded sway bar or not.OEM end links still seems to rein supreme unless you need adjustable then white line.
Maybe I’ve misunderstood but I’ve seen numerous accounts that TS is a known issue. From what I understand it is due to the CV joint angles being different?
My car had what I call the "third gear rodeo" where the stock diff would lock up (like it should) and one front tire would break traction, then the other back and forth a few times. This is not torque steer, which should technically be impossible on the platform if the diff is working properly; both wheels should be spinning at the same speed.These cars don't have torque steer. They break traction. If you have problems that you think are torque steer you have broken or worn parts in the suspension or need better tires or a better alignment.
