JohnnyTightlips
Motorhead
I have had issues with end link clearance since I bought this car and have pretty much let it bother me and ignored it. I am hoping this is the fix but incase anyone else is looking here is a quick install and measurements for the Massive Speed Front End Links. - MASS'13900.7
https://edgeautosport.com/massive-s...rd-focus-st-2013-2018-mazdaspeed-3-2007-2013/
If you did not want to buy these you could make your own. Go here. They were always out of stock so I gave in and got the massive ones. https://midwestcontrol.com/shop/
Bearings, Spherical Rod End Male M10 x 1.50 RH
Item# DWTM-10 $9.44 USD 2 $18.88 USD
Bearings, Spherical Rod End Male M10 x 1.50 LH
Item# DWTML-10 $10.10 USD 2 $20.20 USD
Turnbuckles M10 x 1.50 LH and RH Threads 240mm Overall Length
Item# MHT-M10-240 $5.12 USD 2 $10.24 USD
Rod End Studs Install Your Own M10 x 1.50 RH
Item# SBDW-10 $5.23 USD 4 $20.92 USD
Boots, Rubber 3/8 Female Rod Ends
Item# RFS-6 $4.61 USD 4 $18.44 USD
End links go from your sway bar to your suspension. This allows one side of the suspension to talk to the other side making the car more stable.
Pics
BMW Endlink was already on my car. These are shorter and I was hoping would help but did not. It might work for you.
1995-1999 E36 M3 coupe, sedan, convertible
1998-2002 Z3 M Roadster, M Coupe (MZ3)
MEYLE 3062 - https://www.turnermotorsport.com/p-1766-meyle-hd-front-sway-bar-link-for-e36-m3-mz3/
- Jack up the car - put on jack stands
- Take off front tires
- Remove the top and bottom nut from the End Link you have on now. "You may want to jack up the lower control arm just a bit to get tension off it.
- Install the new one in reverse order. You can check out youtube videos on how to setup the rest.
- Template public:_media_site_embed_youtube not found. Try rebuilding or reinstalling the s9e/MediaSites add-on.
Pics
