DarrinS
Hello all, I’m running into a huge problem on my speed 3. I’m having a cylinder 1 and 4 constant misfire. It will randomly stop and run fine then go back to misfiring. Recently it has not stopped misfiring.
What I have done:
What I have done:
- Spark plugs replaced and gapped
- MAF replaced
- Set of fresh injectors from cwturbochargers
- New battery
- I switched the working coil packs from 2 and 3 and put them on 1 and 4 and they were still misfiring
- Compression was: 1-135psi 2-130psi 3-130psi 4-125psi
