About 4 days ago I went through a puddle and it shut my car off completely and now it won’t crank or start at all. Nothing sounds like it’s engaging. looked at the fuses, starter, battery and I even took the spark plugs out to make sure there was no water in the engine but nothing! Also cranked it manually and it turns. The one thing I did notice was when I took my top mount intercooler off, there was some water in the throttle body it looked like as well as a little bit of dirt?(photo below) Does anyone know the cause of this? Also my battery has finally died from trying to turn the key so much and the car just sitting that now it won’t even jump start. I put the jumper cables on it and let it sit for a bit but right when I press the brakes the dash lights go off and the gauges flutter around. I’m completely lost on what to check with the car. Could it be a ECU problem? Or Antitheft problem?
