virtualsurfer
Hello all!
I've had my speed3 for some time now but I'm new to this forum specifically because I could use some outside advice.
My car has developed a cylinder 3 misfire (p0303) while under boost around 3.5k-4k. The car runs perfectly fine under normal driving circumstances and the idle is solid. I've replaced my plugs with NGK 6509 gapped to 0.032" as well as swapped coil packs and the misfire remained in cylinder 3. The old plugs looked good across the board save for some minor gap changes. The fuel pressure appears to be in order and the fuel pressure relief valve appears to be functioning properly too.
I've noticed when I'm going into boost a cloud of black smoke comes out of the exhaust; could this be related? I know these cars tend to run rich under boost but this was an abnormally large cloud.
Should I begin looking at the injectors and valves at this point?
Thank you in advance.
EDIT: stock except for COBB SRI and HPFP internals. VVT done 3k miles ago.
