MS^ Dead Battery Reflash ECU?
  • Thread starter Thread starter Meik
  • Watchers Watchers 3
Meik
Howdy,
Working on MS6 rebuild. Cannot properly. Dealer installed a 370 CA lawn and garden tractor battery. Constantly recharging; probably playing havoc with PCM line voltage. Installed new "full size" battery. Need to reflash ECU/load new map?
Thanks,
Mike
If you got the map loaded ok before it's still there. Can always redo it now you have a real battery.
shouldnt need to reflash just because the battery is dead. you can flash with the car on a trickle charger in fact is is recommended when running a small battery. no harm in reflashing either if you're worried
Thanks
