Need help, p2187 lean on idle
atorres
I have done a boost leak test but I still happened to have the code. i strayed soppy water on almost every vacuum hose I could see and nothing was bubbling up. I have also replaced the purge valve.I have cleaned the maf sensor. My mods are 3 in jbr sri, corksport hpfp, and i am currently being tuned by freektunes. I am still on a base map. Any suggestions on what i should do next. Here are my data logs.
Intercooler hoses need to be tested. How are you testing the boost leak?
I sprayed soppy water on all intercooler hoses. I did a diy boost leak tester and attached it to the turbo inlet pipe . I also pinched the hose that goes to the valve cover so minimal to no air would go through there. Then I would spray soppy water on the vacuum hoses, bov, and intercooler hoses as well and add compressed air
