2012 Mazdaspeed3
So, I park my car in my garage to do some maintenance.
1. Change valve cover gasket
2. Change Plugs
3. Change oil and filter
so, first thing first, I disconnected the battery just out of habit. Pulled the plugs, then valve cover. Replaced plugs, and taped off and put a coat of paint on the valve cover. (I sanded down everywhere a screw goes in to be safe for random grounds)Replaced the gaskets and re-seated the cover. Tightened the cover down, reconnected the boots and connectors that had to be unplugged (cam sensor) so all is back to how it needs to be. Next, simple oil change, then reconnect battery. Now car is fully back to exactly how it was when parked except, new plugs, oil, and better looking valve cover.
now, the car will not start but will turn over and some tries catch for a split second but leads to nothing. There is spark, all sensors are working. LPFP hums, the only thing I do not know how to check or address is the HPFP.
Any and all help welcome because I’ve been at this for 2 days and a lot of money in replacing any and everything. Thanks!
2. Change Plugs
