I'm in need of some assistance, I recently started the Pro-Tune process. I went out a few days ago and every time I would try to datalog in 3rd or 4th gear it would cut all power at 5000 RPM.
I went out again today and tried again, Traction control off and 3rd and 4th gear. It happened again at both 5000RPM and 5500RPM. At half throttle with boost it acts fine. I was reading another thread on Mazdaspeeds.org and someone said the clutch switch needed replaced, however the car starts fine every time. Just looking for help and ideas, I've included two datalogs, one from 3rd gear, one from 4th gear.
Mod list is as follows
-Kinugawa TD05-H18G
-Mishimoto FMIC with HKS SSQV BOV
-Autotech HPFP internals
-Grimmspeed ECBC
-Catless DP to full 3.5 Inch exhaust
-Damond motorsports EGR delete
-Corksport 3.5 Bar MAP sensor
-NGK LTR7IX-11 Gapped to .026
-Turbo inlet pipe with K&N intake
Thank you!
-Kinugawa TD05-H18G
-Grimmspeed ECBC
Thank you!
