Finally! A baffle that baffles!
Damond Motorsports' Mazdaspeed Oil Pan Baffle is designed to keep the oil pickup tube supplied with oil during hard cornering and braking. Featuring two vertical baffle plates with 1-way trap doors, this oil pan baffle is the first of its kind to offer actual baffling with trap doors for the Mazdaspeed platform.
Whether you track/AutoX your car, drive hard on canyon roads, pull some impressive G's on your favorite on-ramp, or you're just building a motor and deleting the balance shaft assembly, the Damond Motorsports Oil Pan Baffle will keep your oil where it needs to be at the pickup.
The Oil Pan Baffle does require the installation of a Balance Shaft Delete, but we've got you covered there with our very own Balance Shaft Delete, or BSD for short. More info on that here.
Fits engines:
Fits engines:
- 2005-2013 Mazda MZR DISI 2.3 Turbo engines
- 2006-2007 Mazdaspeed6
- 2007-2013 Mazdaspeed3
- 2007-2012 Mazda CX-7 2.3 turbo only
