We are excited to launch our Mazdaspeed3 Engine Oil Cooler Kit!
https://damondmotorsports.com/collections/cooling/products/mazdaspeed3-engine-oil-cooler-kit
When we set out to make an engine oil cooler kit for the Mazdaspeed3, we wanted to build a kit that would not only aid in engine oil cooling, but would maintain proper oil temperatures, and reduce engine coolant temperatures. We have accomplished this in our Engine Oil Cooker Kit for the Mazdaspeed3. If you track your Mazdaspeed3, have a high horsepower build, or just push their car to the limit every drive, then the Damond Motorsports Engine Oils Cooler Kit is for you.
Product Details and Benefits:
For more info, check out our blog on oil cooling: https://damondmotorsports.com/blogs...he-damond-motorsports-engine-oil-cooling-blog
- Machined oil cooler adapter sits atop the oil filter housing, allowing for both cartridge and spin-on oil filter housing fitment. Since it's not a "sandwich" style, you can use standard and over-sized filters without issue.
- Deleting the factory cooler results in lower engine coolant temperatures under hard use.
- Due to the high flowing design of the adapter and omission of the factory cooler, pressure drop is negligible.
- Remote thermostat allows oil to obtain and sustain proper operating temperatures. Thermostat is set to 180F.
- 19 row stacked plate oil cooler features -10 flare fittings, reducing the amount of fittings used.
- Lightweight nylon over stainless braided hoses, fully assembled with -10 fittings
- 5 total 1/8" NPT sensor ports. Allowing for greater flexibility when adding/mounting oil temperature and pressure sensors.
- On track testing has shown around a 30°F decrease in engine oil temperatures and around a 10°F decrease in engine coolant temperatures.
