SGVMS3
Hello everyone this is kind of an introductory post and also a cry for help. Im the new owner of a kind of rescued 2008 Mazdaspeed 3. I really need some help because this thing needs just a little love to get back on the road. I need to get it smogged asap (DMV giving me 30 days smog exemption) then will get it fine tuned to run at its best.
Its been sitting a while but seemed to be running well at first. Its been modded by owner #1, I got it from owner #2 and he wasnt able to offer too much info on it. From what I gather the car has these mods:
Greddy Turbo
FMIC (dont know the brand)
3 port boost
JBR Racing 3.5" intake
HPFP
Cobb AP with freektune
Had an ungodly full catless CNT exhaust, but car came with factory DP so I put that back on and now its much bearable to drive.
It seems I will need to get another protune to make sure all the sensors are on and smog ready and account for the new exhaust. When i try to run a cobb OTS tune just to see if it will run, the car immediately starts and shuts off, I presume this is due to the intake requiring custom tune?
My main problem right now is a misfire code p0301. It seems to run fine when i clear the code but it always returns after driving a little. Im not pushing the car very much when I drive.
Ive moved the coil- code remained- so replaced spark plug with NGK iridium gapped to .028. Not sure if means anything, but ignition coils all have .177 ohm reading(decimal placement could be wrong)
Im not a pro at all when it comes to these modded cars. Ive tried to do as much reading on this I could find and it seems that Im left with 2 possibilities. I either need to do a compression test or pull the intake and check the injector. Would the compression test still be accurate if an injector seal is bad? Comp. test would reveal whether that particular cylinder is low but wouldn't tell me why its leaking (i.e pistong rings vs injector seals).
Sounds like I need to cough up the $175 or so for a set of corksport injector seals? These seem to be the only other option aside from buying weak OEM seals at $50 each??
Given the time table with the DMV Im scrambling to get this resolved. Am I on the right track with this? I dont mind spending money to get it right but dont want to guess and throw parts at a modded car like this. Thanks in advance for anyone that can help!
Greddy Turbo
3 port boost
HPFP
