Jvannote
I'm totally stumped. I've been searching the forums and so far no luck fixing my issue.
I have an 08 MS3, replaced the engine with a jdm import about 2 months ago. Car was running great, then had a stalling issue when it was hot. Fuel pressure was holding, then dropped to 3 psi and car stalled. Managed to get it restarted, drove for a bit then same issue. Had it towed home, sat over night, started with no issues. A few days later, same thing.
I have since replaced the fuel pump, tested the resistor (no issue there), checked all wiring, swapped HPFP with the one from old engine, swapped fuel pressure relief valve,, and checked all fuses, relays, and wiring. Can't get the fuel pressure to get over 5psi. Really not sure where to go from here. Is there a test procedure to make sure I getting the right voltages at the fuel pump harness? Any help at this point would be greatly appreciated.
