Lobster
I have a 06 Speed6 that I purchased in rough condition. The car is very low on power, even revving feels incredibly weak. I doubt it could go any faster than 30mph. I’ve attached logs of the car idling with a few small blips of the throttle.
AFR was surprisingly normal at 14.7, and 13.x under light load. There are no check engine lights either.
In the logs, I noticed that the mass air flow rate reading was low and replaced the MAF sensor with an oem one and it made very little difference. Fuel pressure sensor, hpfp internals, and fuel filter have also been replaced so far. Any advice is greatly appreciated, thank you!
