dinnerplate
Been trying to figure this out for about 2 days now. My 2013 speed decided randomly it was done turning over--the night before it was just fine. Next day after work, nothing.
Oddly, symptoms seem like it would be the fuel pressure relief valve. Not the case though. Just in case though, I've done the following:
- Swapped over to known good HPFP from my '08.
- Swapped over *brand new* fuel pressure relief valve.
- Swapped over just the spill valves
- Cleaned both HPFPs and spill valves
- Swapped over known good fuel injection harness from my '08.
- Checked and verified grounds in the engine bay
- As a sanity check, I did check the pump resistor as well. Just firing off parts at that point. Swapped over a known good one even though the resistance was in spec.
After letting it sit for another day, or after swapping HPFPs, it will turn over, and then die off. Then it will cease to turn over again. I have just about every imaginable code for fueling. I'm beginning to sense a larger issue here. The car will run without the spill valve connector. Which is what pointed me to thinking that it was the relief valve.
Car has next to no modifications. I mean, the engine itself is a freshly built engine the previous owner had a shop do, but the only actual modifications it has are an intake and a catted downpipe. At this point I'm stumped--I'm hoping it's mechanical because I hate tracking down electrical problems in cars.
Surprise, here's a datalog of me trying to turn the car over.
