Hello Everyone
Just migrated over here from the Mazdaspeedforums so I will post a similar intro thread as I did over there. Really enjoyed the response i was getting from raider when I signed up. I got the car a little over a month ago and its been a blast to drive but the issues started coming. I inspected it myself and had it inspected by a mechanic and decided to give buy it. I got it with about 74500 miles and now I am close to 78000. The previous owner modified it to run the cobb stage 2 OTS map so the car came with
COBB Tuning Accessport V2
COBB Tuning short ram intake
CPE turbo inlet pipe
Forge bypass valve
Auto Tech Cam driven fuel pump internals
Turbo XS Downpipe
Vibrant Cat Pipe
Vibrant Cat Back Exhaust
Upgraded Rear Engine Mount
Denso ITV22 one step colder spark plugs gapped to .026-.028
I had the anticipated smoke from the exhaust early on but I raised my idle to 900 using the cobb accesstuner and changed my oil to rotella 5W-40 and its been relatively fixed. I understand that the seals are bad and the turbo needs to be replaced ASAP but I am holding out until I take care of my main issues which is the VVT started making noise a few weeks ago. So all my free time lately has been spent researching, reading forums, messaging members, talking to mechanics, and acquiring materials. Should be getting around to it this weekend or the following. Crossing my fingers that my engine doesn't fail before then so no spirited driving in the mean time. Anyone in the NJ/PA/NY area who wants to hang for the weekend and help a noob out is greatly appreciated.
Reading around my plans with the car are as follows but feel free to chime in
VVT actuator/timing repair (already have the kit from edge with the SSTs)
fix incorrect purge flow - P0441 (previous owner recommended new purge valve, already ordered)
transmission fluid to FoMoCo, oil catch can, banjo bolt, EGR delete install, new air filter, BPV servicing, intake valve cleaning
front mount inter cooler upgrade and e- tune
big turbo upgrade (BNR s4?) and retune
meth injection and retune
suspension upgrade
brake upgrade
Forge bypass valve
Turbo XS Downpipe
Vibrant Cat Pipe
suspension upgrade
brake upgrade
