Official Intake , TIP, MAF Thread
JohnnyTightlips
Motorhead
##### For any intake that is not stock sized you will either need to get the small battery tray "51r" or relocate the ecu on top of the fuse box and delete some of the battery box. #####
Intakes by Company "a-z"
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
AEM
AEM 21-642C Cold Air Intake
Stock MAF - No Tune Required
https://www.aemintakes.com/cold_air_intake/mazda_mazdaspeed3.aspx
ATP
ATP Turbo 3" MAF Housing Billet Aluminum for DENSO Element
Tune Required
https://edgeautosport.com/atp-turbo-3-maf-housing-billet-aluminum-for-denso-element/
ATP Turbo Short Ram Intake Mazdaspeed 3 2007-2013
Tune Required
https://edgeautosport.com/atp-turbo-short-ram-intake-mazdaspeed-3-2007-2013/
COBB
MAZDASPEED3 INTAKE + AIRBOX GEN1 MAZDASPEED3 2007-2009
Tune Recommended
https://www.cobbtuning.com/products...eed3-intake-airbox-gen1-mazdaspeed3-2007-2009
MAZDASPEED3 SF INTAKE SYSTEM MAZDASPEED3 2007-2013
Tune Recommended
https://www.cobbtuning.com/products/air-induction/mazdaspeed3-sf-intake-system-mazdaspeed3-2007-2013
MAZDASPEED TURBO INLET HOSE
https://www.cobbtuning.com/products/air-induction/mazdaspeed-turbo-inlet-hose
CorkSport
3.5" Mazdaspeed 3 Power Series Intake System
Tune Required
https://corksport.com/mazdaspeed-3-power-series-3-5-inch-intake-system.html
Mazdaspeed Turbo Inlet Pipe
https://corksport.com/mazdaspeed-turbo-inlet-pipe.html
Mazdaspeed 3, 3" Power Series Intake
Tune Required
https://corksport.com/corksport-power-series-2007-2013-mazdaspeed-3-big-maf-3-intake.html
Mazdaspeed 3 Stage II Power Series Short Ram Intake
https://corksport.com/mazdaspeed3-short-ram-intake.html
2007-2013 Mazdaspeed 3 Silicone Intake Elbow
https://corksport.com/corksport-mazdaspeed-power-series-intake-elbow.html
Short Ram Intake for Mazdaspeed 3
https://corksport.com/mazdaspeed-3-short-ram-intake.html
CP-E
cp-e™ Nviscid™ Mazda MZR 2.3 DISI Mazdaspeed Turbo Inlet Pipe for Stock Turbos
https://cp-e.com/shop/product/mzr-2-3-disi-nviscid-pipe/
cp-e™ Nviscid™ Mazda MZR 2.3 DISI Mazdaspeed Big Turbo Inlet Pipe
https://cp-e.com/shop/product/mazda-mzr-2-3-disi-nviscid-turbo-inlet-pipe-for-big-turbos/
cp-e™ XcelXL™ Mazda MZR 2.3 DISI Mazdaspeed Intake
Tune Required
https://cp-e.com/shop/product/mzr-2-3-disi-xcelxl-air-intake/
cp-e™ Xcel™ Mazda Mazdaspeed3 Cold Air Intake
Tune Required
https://cp-e.com/shop/product/mazdaspeed3-xcel-cold-air-intake/
cp-e™ XcelNANO™ Mazda Mazdaspeed3 Intake
https://cp-e.com/shop/product/mazdaspeed3-xcelnano-air-intake/
HPS
HPS SRI Short Ram Air Intake + K&N Filter for 07-13 Mazdaspeed MS3 (Black)
https://www.ebay.com/itm/HPS-SRI-Sh...r-for-07-13-Mazdaspeed-MS3-Black/191947179711
HTP
HTP :) I recommend every get the 3.5" and call it a day, this is perfect for 90% of drivers even with a bigger turbo until you go PI and built motor then go 4".
HTP Mazdaspeed 3.0" - 4.0" Open Air Intake System/Recirculate - No Air Straightener/Straightener
Tune Required
http://www.hitunedperformance.com/htp-mazdaspeed-3-0-full-intake-system/
http://www.hitunedperformance.com/htp-mazdaspeed-3-0-open-air-intake-system-no-air-straightener/
http://www.hitunedperformance.com/htp-mazdaspeed-3-5-full-intake-system/
http://www.hitunedperformance.com/htp-mazdaspeed-3-5-open-air-intake-system-no-air-straightener/
http://www.hitunedperformance.com/htp-mazdaspeed-4-0-full-intake-system/
http://www.hitunedperformance.com/copy-of-htp-mazdaspeed-4-0-open-air-intake-system/
HTP 3" Mazdaspeed Turbo Inlet (Black Powder Coat)
Tune Required
http://www.hitunedperformance.com/htp-3-mazdaspeed-turbo-inlet-black-powder-coat/
Injen
Injen Cold Air Intake BLACK Mazdaspeed 3 2007-2013
https://edgeautosport.com/injen-cold-air-intake-black-mazdaspeed-3-2007-2013/
JBR
K&N
RamFab
Spectre
Looks great. I'll try and add the info for the one I'm using, I have the MAF size and all.
[doublepost=1555110701][/doublepost]Never mind, you have the HPS SRI listed. Btw in case you want to add, the pipe and maf size is stock, I actually measured it at 67mm. The stock number is 27-601. Comes with kn filter and bolted right in.
I hope go GOD, there is no copy paste stuff man. It's something that can get me sued. Be careful. Ideally it would be all your text, colors etc
