SlowSpeedT
I plan to replace the hose but the oil leak is pretty bad from there. What might cause this? Bad PCV? Bad turbo? Leak coming from valve cover side of the hose.
for additional context: I’ve had this 2012 Mazdaspeed 3 for a few months. All things were fine but I was consuming about half a quart in about 800 miles. The car has 83k miles on it. Mods in include the following:
Corksport Short Ram Intake w CS turbo inlet pipe.
Forge BPV
Auto tech HPFP
Short shifter
Damond rear motor mount
(No tune but have AP to do so once I add a couple more mods)
I decided to change the spark plugs and as suspected the current ones looked terrible. Did find a little oil in the TMIC. Got the new plugs pre-gapped but still measured just in case. Didn’t drive the car just started it up for a few minutes no problem. Next day I went to change transmission fluid and noticed a small puddle of oil. Looked up and saw oil all over motor/rear motor mount etc. upon inspection the highest point I could find oil was where the hose from the turbo inlet connects to the valve cover. I also noticed previous owner zip tied the hose which probably indicated it’s leaked from there previously. That’s about all I have.
Forge BPV
Auto tech HPFP
Short shifter
