Year/Make/Model: 2007 Mazdaspeed 6
Mileage: 140500
Concern: Overheating
DTC's: None
Modifications: None
ECU/Tuning Software:
Tuner: Cobb Accessport V3
Recent Repairs: Heads Machined, Head Gasket, Water Pump, Radiator, Thermostat
Correction:
Need some help dealing with an overheating issue. First started about 8k miles ago, had the thermostat replaced first then did compression leak test, determined the head gasket needed to be replaced and heads machined. Radiator then sprung a leak and had that replaced. A few thousand miles later, started overheating again randomly. Replaced water pump to no avail. Had shop look it over and found no leaks in coolant system or combustion leak into coolant. Car will idle all day long and never overheat. Can rev the car and it will never overheat, only when driving is it randomly creating an air pocket. Need another place to look before I give up.
Mileage: 140500
DTC's: None
Modifications: None
Correction:
