P0069?
jsilva
I’ve seen P0069 come up twice in the last few weeks. It comes at start up. I know what it means but I’ve found very little information searching it up. The best I could find is a potential problem with the MAP sensor, but wouldn’t that be more regular? I wondered if maybe a dirty MAP sensor might result in that code coming up intermittently?
Any thoughts would be appreciated.
Not sure if you fixed it yet or not but I just had the same problem. Will at PD ended up fixing mine with the tune but if you haven’t changed anything I would first check the ground plug on the driver side frame rail. It’s a flat white connector bolted to the frame with 4 wires plugging in to it. Unbolt it and clean the frame where it bolts to and all the spades and connectors. If that doesn’t do it I’d check the wiring harness coming out of the map sensor just to make sure nothing rubbed it. Then I’d probably replace the map sensor if it’s not the other two things. But checking and doing this is free. I would have never figured out my codes/electrical issues if it wasn’t for the guys on here.
That rust should get taken care of before it gets worse.
That’s not my car lol. It’s just a reference pic that sho sent me when I was having this problem
