S silas Greenie N00B Member Feb 22, 2020 #1 just got this code says park/neutral switch input circuit and a pcm code. only mods i have is the cobb AP and corksport intake. Where should i start?
Ssinstaller Greenie N00B Member Greenie Member Feb 22, 2020 #2 At the neutral position switch in the transmission.
Awafrican Moderator Gold Member Feb 22, 2020 #3 Also check the connection & harness going to the transmission
Ssinstaller Greenie N00B Member Greenie Member Feb 22, 2020 #4 The wire to test is in pin 1s(it's voilet)at the ECM. Should have 12v when the transmission is in any gear, and drop to ground in neutral. Attachments download.jpeg 534.4 KB · Views: 21
S silas Greenie N00B Member Feb 22, 2020 #5 Ssinstaller said: At the neutral position switch in the transmission. Click to expand... where is the switch located?
