liquidefex
Year/Make/Model: 2009 Mazda Mazdaspeed 3
Mileage: 196582
DTC's: P2188 and P0302
Modifications: Cobb intake, EGR delete, balance shaft delete. rebuilt engine myself, now has about 10k miles on it. all machine work was NOT done by me. bored out .5mm over, same internals except pistons, same crank, rods
ECU/Tuning Software: none
Tuner: none
Is the concern intermittent? No, it is constant
Can you duplicate the concern? Yes, seems like misfire is really exaggerated under load, like 3k-5k RPM
Recent Repairs: new plugs gapped properly a few thousand miles ago
Correction: none yet
Been reading a bit about it on the forums, could be fuel injector seals? I did the fuel injector rebuild kit when I rebuilt the engine.
Did four new spark plugs a few months ago I wanna say, properly gapped all of them. The ignition coils are a mish-mash...some OEM, some not.
Haven't taken the plugs out quite yet to inspect, and I plan to do a compression test in another couple days when the tool gets here.
Attached is a screenshot from bluedriver about misfire info, as well as CSV of the logs from about a 10 min drive, around the 520 second mark I got into the throttle quite a bit, and the misfire got so bad that the CEL went from solid yellow to flashing yellow, then returned to solid a minute or so later.
Any help is appreciated. I'll be tearing into it later this week or probably next week, just wanted to get an idea so maybe I can order some parts before it's taken apart in the driveway.
Thanks guys!
Mileage: 196582
Tuner: none
Thanks guys!
