PARASITIC DRAW
ZachB123
Silver Member
Hey all, I know this is probably a common issue that you have already solved but so far I'm having no luck. I currently have a 1.8 to 1.6 Amp draw coming from my 15amp ROOM fuse. Removing the fuse drops it down to .03 amps and I have already attempted all other fuses on the vehicle engine bay and interior. I have unplugged the original and aftermarket sound system and removed the radio with no change whatsoever. I've heard it's all really messy and connected to the BCM, lights, and practically everything else on the inside. Is there any other quick checks I should do before diving into more wiring? Let me know... below is a checklist of what I've already examined.
Moonroof, trunk light, passenger door sensor, radio (aftermarket add on and original), voltage regulator/alternator.
Please help!
I know on the GenPu, the sensor that triggers if the door is open can flip out and think its open.
I'll have to check that out too, saw some stuff on it but haven't looked into it yet. How do you know which door it may be?
That would be the billion dollar dollar question.
When I had a door sensor go bad it was a matter of catching the indicator on the dash while I was driving. Unfortunately it took it getting pretty bad before I was able to determine. Turn off all the interior lights in the meantime
