* port fueling options
Meicalnissyen
Has anyone tried the CP-E fuel bar ?
It under mounts the injectors.
I have not seen pics, is there room?
Probably not.
Edit: Maybe if you use the stubby injectors. If there's clearance, this might be the go-to setup for TMIC guys like me.
Good god man
it is a veritable silver mine of platinumness
verra nice
The CP-E in Titan would match well
I finally got the RS mani, so I own both the ST, and RS there are some dif's but TB dia, and 5 bolt pattern same
and both have huge interferance with the CP-e bar along the underside , the flange eclipses appx 50% of the injector bore (which uses only the short fat injector style)
The asymetrical Mazda ports become a driver here as well. I am having much fail trying to rummage about the ford stuff bin
Where did you read the CP-E bar undermounts the injectors?
If you want moar fuel and keep TMIC then single injector in CAC pipe pre TB is the way to go.
Oh it wasn't read about, It was I figured it would fit, discovered that part out when Alex and I are trying to test fit to the head, and mani.
So it doesn't match the port shape on the head?
No but you could stack a DM plate with it probably (lol).
CP-E support as useless as ever.
Thank you for confirming what you need!
We have never tried one, but it is very similar.
We unfortunately do not have these in stock. At this time we do not have them on our production schedule.
Sorry we can’t be of further assistance. Thank you!
