j-modig
Hi,
New user here, trying to troubleshoot an error code on my son's 2007 speed 3 (or MPS 3 as they are called here in Sweden).
Code is P0069 according to Dashhawk:
I can display readings for MAP and Baro. When turning on ignition (without starting engine) they read 70 and 98 kPa respectively. I guess, at least in theory, they should be the same = ambient atmospheric pressure (which happens to be almost exactly 98 kPa).
When starting and driving MAP drops as vacuum builds in the intake while Baro is pinned at 98. MAP reading seems very consistent with driving, only the scale seems offset.
Car runs perfect though. No hesitation when accelerating and no rough idle.
A crappy video giving some gas in third. Hard to see but you see MAP rising and briefly running higher than Baro (=boost).
Any input suggestions or speculations welcome
/Johan
/Johan
