Rodney Alvelo
Hi, so I've been having this issue with my speed 3 for about 2 - 3 weeks now and I still can't figure out what is causing the problem. The car would idle fine but under load it would start to break up. I've done new plugs gapped to .026, I've checked my coil packs and they are good, I've check for vacuum/boost leaks and nothing, I've also done a compression test and is 180 across and leak down was good too but I still have the issue. I just replaced the fuel pressure sensor yesterday and now the idle is a little rough with a pretty noticeable misfire and my HPFP psi will only go up to 1400sh on a WOT pull (before replacing the sensor I would go up to 1900sh) so I don't know if I got a bad sensor or it's normal. I haven't pulled the injectors yet and I'm the 3rd owner of the car so I don't know if they've ever been serviced so I'm going for that next.
Would like to know if there's something I'm missing because at this point am just guessing and just throwing money at it.
Please help!!
I added 2 WOT logs from today hopefully it helps
Please help!!
