im trying to rebuild my differential that ran low in oil and started to make a wining noise. Im trying to figure out a way to remove the 46mm nut without using the Mazda oem tool to hold the shaft splines. Do any of you have ideas or did it by another mean ?
i thought about putting back the gears and put a towel to jam the pignon against the larger gear. what do you think?
Or is there another thing that could fit the shaft spline and can be used to make a tool?
My last option would be to just replace the side bearings and put it back toghether but being at it, if the side bearing get worn, the pignon shaft ones are probably in the same shape...
