Can someone help me quell my OCD over ring gaps? I'm getting 87.75 Manley's and was thinking to do .020 top and .024 bottom like JT. Then Sho says these engines like .03 between rings and that .027 is way to large and will burn oil. Then CP recommends .04 between rings. I understand you need some space in between to prevent flutter. HP goal is around 500-600 with returnless PI. I want to see how it goes since it's so simple then maybe do return pi. I also want to build the engine once so it can handle 700 where the stock sleeves become the weak link. There's an MS6 making 800whp with stock sleeves.
Crank bearings also worry me. I'll be using Clevite AL MS-2245A. JT pushes big power on them which boggles my mind since bi-metal bearings are meant for oem level +50% above power. I heard somewhere tho some bearing manufacturers like to underrate their bearings so they can sell other ones. SP63 also does this: "In order to get extra oil to the rod bearings, we create a teardrop shaped cavity to the crankshaft's main oiling holes". I heard good things about King PMAX black and clevite H mains are impossible to find now. This will be a DD. I have clevite H rods.
At what point should you worry about crank Keying? Or is it not necessary at all? The ARP crank bolt has a tq spec at 140ft lb and another member found that the oem TTY is at 280ft lb. Seems like the ARP is too low.
