Ziad Joumaa
I have an 08 Mazda S3 that was brought to me by a friend of a friend. The story is old engine went and they paid a shop to put a be one. Now it’s been running ruff ever since with a strong gas smell/rich smell. It was later taken to a reputable tuner who smoke tested it replaced a bov that was also jb welded back in. Comp tested and re mapped via cobb. He came to the conclusion it might need injectors but hed need to send them out to be sure. Owner didnt feel like spending that much more.
Something concerning me is the shop put jb weld on the top of the spill valve/relief for whatever reason. It holds 900-1000 psi of fuel pressure at 700-850 rpm idle which seems too high to me. AFR’s sit at 14.7-15ish which is acceptable to me but doesn't explain smell.
Things I've done:
Removed injectors for inspection and they seemed fine, gave them a back yard cleaning wth a ultra sonic cleaner reinstalled with no change. I know im suppose to do seals and i cringed re-installing but i couldnt justify telling him to spend X $ for a maybe.
Replaced Plugs because they were gapped to .16-.18 which seemed very tight to me and regapped new ones to around .27, car idled better and stopped throwing a miss fire code, yes i think 2 were fouled.
Smoked test again as well as a coolant pressure test thinking someone might of missed a vac leak or turbo seals were going because the intake/throttle body section was disgusting.
Removed MAP and tried running but it starts and dies immediately or wont even run. Seems odd to me every car ive done this with will run somewhat but if it has no reading it’s basically not running.
Conclusion:
Im very focused on the hpfp section now because of the abnormally high reading at idle even though during accel it does go up to 1400-1500ish psi but it will not go lower then 900. Also the jb weld thing has a story that no one knows. Im pretty capable but I wanna be more confident before i start throwing more money at it because it will get pricey fast.
Mod list: some sorta dp, maybe a cat back, cai, aftermarket bov, Cobb piggy back,
Let me know if any more information is needed, appreciate everyones time.
Things I've done:
Conclusion:
