BaiJie90
If you have a sunroof, it is possible a drain tube had plugged causing rainwater to leak into the car.
Also possible is the A/C system leaking due to a plugged HVAC case drain. Check to see if water flows out the drain tube on the firewall or try clearing it by shoving a piece of wire up if plugged. Or this related issue.
Pull up the front carpet at check to see if it shows signs of wetness or has a musty odour.
I had an issue with my A/C expansion valve freezing up and causing a small amount of water to soak the passenger floor carpet.
Also check the seams at the bottom corner of the rear window. The seam sealer cracks with age and can cause leaks.
I have had all these issues with cars over the years.
I followed most of your suggetions, I have no sunroof so that one is rulled out. So there is water flowing out of the drain tube on the fire wall. Would it still be possible that it leaks in the cabin? It didn't feel wet or had an odour, but I might have to double check this.
Furthermore I don't see a connection from a leak in the front passenger seat to having rust at the rear, maybe you can elaborate more?
I still have to check for leaks at the rear window. And another question, will the carpet like show any signs of a leak, besides wetness? Like extra wear or something, or even a different color?
Thank you![]()
I had an issue where the water would weep back from the drain outlet and soak the foam seal at the firewall. I then applied a zip tie to force the water to form a drip before reaching the firewall. If the drain is working properly, it should not drain into the interior. If plugged, it can fill up the bottom of the HVAC case and leak inside.
As for the water originating in the front, it can flow from the front to the rear. The reason the rust is at that place on the pan is because it couldnt flow any further.
The easies was to diagnose previous wetness is to look at the jute insulation backing. If kept dry it maintains it structure, but if its been wet it regularly sticks to the floor and comes apart in layers. You will also find rust under the asphalt melt sheet sound deadener. These might help you trace the water flow back to the source.
