Smoking Downpipe from Hell
modusoperandi
Was doing a downpipe install today on my car, UPS screwed me by not setting up a pickup at the sorting facility so started working in the heat & I'm pretty sure I fucked up on the install somehow that when I turned on the car well its smoking to hell & I'm trying to figure out where the hell it's coming from. Also I did use quite a lot of Liquid Wrench to get the studs off to install the new ones I ordered. Used a lighter & the top studs are find & once I get to the undercarriage it snuffs itself out slowly. This is tons of fun figuring out.
If out tailpipe. Normal. Rest, normal. Oil all over. Go drive it.
Its coming from the engine bay all of the smoke, all of the smoke got me damn lightheaded... Been driving it in intervals.
If it doesnt go away after a heat cycle or two try a long neck lighter. If it flickers near the exhaust flanges, you may have a leak.
I'll drive it tomorrow & see if most of the liquid wrench burns off after the drives. Its just way too much fucking smoke lol. I actually started to check with a longneck lighter & it was turning off near the end of the dp.
Put a shopvac in your tailpipe and set it to blow and then listen for hissing.
I'll do that, just gotta find our shop vac. I was trying to use rags to clog one pipe & put a rag in the other. The exhaust pressure kept pushing them out.
