Getting ready to install my SP Stage 2 kit. What boost level should I set the controller to start spraying and max flow boost? My current map is a reverse taper 26 psi boost target.
It's anyone's guess as to what you actually set the controller to as the hatch marks on the little knobs are 4..... 19 within a half inch. I set my system to start at 9 and 100% at 16psi. Max boost I see is 24-25psi.
FWIH, adjust to start spraying at half of max boost (so 13psi), and set to full spray at 3/4 of max boost (so ~19.5). Those are good rule-of-thumb starting points. Depending on the mix you run, if you feel bogging, have other issues, etc., then you may have to adjust it more.
