Speed 3 & Speed 6 Vacuum/Boost Distribution Block
CorkSport - Derrick
We created the boost and vaccum distribution block to make it an "easy button" to get things routed and cleaned up under the hood of your DISI powered Speed.
The vacuum block was made designed to maximize the number of boost ports while remaining very small. Final dimensions are 3.5 x 1.25 x .6 inches, with the main body being shorter at 2.5.The small size with the end mounting location gives freedom to mount just about anywhere that uses an M8 or smaller bolt/stud.
Ports are all 1/8-27 NPT thread size and we offer an option to get barbs and push connect fittings included with the block.
