JohnnyTightlips
Motorhead
Fixed, yes just do add-a-fuse.There are 2 pics not showing, the first and the "Plugs that go to PI injectors"
I'm doing this this summer. Add-a-fuse still the way to go?
Bro same im thing to figure out how to get a test map but could not find anything. I'm too scared to mess with the controllers settings but no one will reply with a link to a test map. If anyone has one it would be greatly appreciated.
Hello im wondering for the test map with map A and B. Do I do the fuel maps the same or only do map A?The test map only has data in these cells. .7v -1.3v 500rpm to 3000rpm You could also just make it yourself. It is telling the Split Second to spray fuel at idle maf voltage and rpm "so you can plug them in one at a time like the video and make sure they are spraying". Map A and B should match. If you can't figure this out you should probably pay someone to tune the car lol.
A and B should always match.Hello im wondering for the test map with map A and B. Do I do the fuel maps the same or only do map A?
