[SOLVED] Started car after storage, cuts out (P0091, P0192, P0193)
Anthony Pham
Hello all!
I started the car last night after sitting for 4 months; primed the car at least 5 times before starting. Initially it started and idled fine - after 2 mins it began cutting out. Last night I got codes P0091 and P0192.
Today I tried again after cleaning the connection/plug for the fuel rail pressure sensor. Started fine but died after 1 minute. This session of starting the car gave me P0193.
I took a video of my AP showing the wacky fuel pressure voltage and pressure. First video is idle, second is KOEO.
I'm leaning towards that the fuel rail pressure sensor has gone bad. Any advice?
Thanks all in advance.
Does the battery have a completely full charge? These cars will run like shit on a weak battery
Voltage wise, i'm getting 14.1's when the car is on. The battery was stored inside my house until a month ago where I put it back into the car but with a battery tender. Amp's wise, not sure.
14.1 running just means your alternator is working. What's the voltage with the car off
Do you remember what the part number was or where you found it? I can’t find it anywhere.
