Pearly_White_GenPu
My situation will be a bit long to type out and describe, so I'll try to keep it relative to each section of the Troubleshooting Template. Bear with me, and I apologize if it looks like a pain in the ass.
Year/Make/Model: 2013 Mazdaspeed 3
Mileage: 79,800
Concern: Fuel Trim/ECU Tune. STFT pops from -14% and up to +29%. LTFT seems to stay from +14% to +17%. I may or may not be a complete idiot being that I'm entirely new to data logging and what parameter ranges to look for on this car, but if I'm not mistaken, I don't seem to be running lean with my A/F actual outside of when I'm decelerating. If anything, I seem to run rich when giving it decent throttle. I have no idea if it would be possible to tell but if it is, I need to know if the car appears to have a factory tune, or if it is possible the tune that was supposed to be on it still is and there's just other issues causing such wild readings. I also know that I have a boost leak that I need to hunt down once I actually finish with my move - I'm between houses right now - but I'm not sure whether its bad enough to throw it so far out of range. Its somewhat audible and starts leaking after a certain threshold (when the stock gauge hits between 4-2 vacuum), but otherwise seems okay for the most part if I just drive lightly. The car ironically runs really well, believe it or not. My top suspicion right now is that its leaking from the BOV, like from the cap sealing o-ring or something. The area that the leak sounds like its coming from in the cab is exactly where the BOV is.
DTC's: P0069 for MAP; P0101 for MAF "A" Circuit Range; P0421 for Cat Warmup Efficiency (I have a catless DP, so.)
Modifications: JBR SRI/TIP, upgraded TMIC (Looks like corksport from what I can tell), TurboSmart Supersonic BOV, 3" Catless DP, 3" Catback exhaust. Allegedly has HPFP internals but I have not confirmed - The housing looks relatively new though, so I'm praying its not some ebay BS -
ECU/Tuning Software: Car was tuned with a v3 AccessPort, but the AP was stolen out of the car while still with the seller. The tunes it had were supposedly for 91 Oct and another for E85, so I assume it had to have been some sort of custom tune or at least an OTS+ like what freektune offers. This is why I ask if it is possible to tell whether it is still running one, being that if the person that stole the AP actually had a brain, they would have unmarried it and flashed the ecu back to factory. I bought a v3 the other day and only have not hooked it up for this reason, since I'd rather it run a tune that accounts for the mods until I get everything worked out with it to get my own tune done, rather that wipe the ecu and be forced to run some OTS tune that does not match what I have.
Tuner: N/A
Recent Repairs: N/A
Correction:
These logs were just casual driving as I went out to get food. I take it really easy on the car being that I know there's a couple issues I need to address, but I did practically go WOT in the second driving log in case there was anything outside of the stupid low boost level that might be helpful data-wise.
Warmup From a cold start:
https://datazap.me/u/pearlywhitegenpu/log-re-do-troubleshooting-warmup-1?log=0&data=5-6
Log of just idling once operating temp:
https://datazap.me/u/pearlywhitegenpu/idling-log?log=0&data=4-5
Driving Log 1:
https://datazap.me/u/pearlywhitegenpu/log-re-do-driving-1?log=0&data=4-5
Driving Log 2:
https://datazap.me/u/pearlywhitegenpu/driving-2-re-do?log=0&data=4-5
Mileage: 79,800
Tuner: N/A
Recent Repairs: N/A
Correction:
Driving Log 1:
Driving Log 2:
