So unfortunately the Mazda is driving like shit these days and I'm getting desperate for some help.
- Verified no vacuum leaks or boost leaks, I used the smoke method, soapy water method, and carb cleaner method. Whenever I pressurize the system, all I get is flow coming out of the valve cover.
- verified spark plug gap at .026" and changed spark plugs within the last 1000 miles
- cleaned MAF sensor
- stretched ignition coil springs
- added fuel system cleaner
nothing is working.
I'm starting to think the primary o2 sensor or MAF sensor is going bad
I took a 37 min log on the way to work this morning. I thought almost a dozen times I was going to have to pull over. Its just strange that sometimes my fuel trims are fine and then the next moment its at 26%
Any help is appreciated
nothing is working.
