This is a weird one. For the last month or so, I'm noticing this odd stutter at very low throttle openings - essentially, when at cruise or barely accelerating. It feels like a momentary buck or stutter and always happens at between 2 and 3,000rpm. I've checked for vacuum leaks and everything feels tight. I removed and cleaned my MAF sensor, no difference. My plugs have around 8,000 on them and should be fine. No stored codes.
I went and took a log to demonstrate what I'm seeing, and the throttle position column appears to demonstrate what I mean - my speed holds steady, as my foot isn't moving - but the TP numbers dip down to 7, then up to 12, back to 7, etc several times.
My first thought is a failing throttle position sensor, or a primary 02 sensor on the way out. Any other ideas? Thanks all.
