[SOLVED] stutter/vibration, Cyl 1 codes
Luckie17
Autotech fuel pump internals
EGR Diamond delete kit
K&N short ram
NGK 6510 .27 gap
new oem injectors with graveyard seals
CS fuel line
oem FPRV
Hello friends,
Im back again with some new issues now that I finally got my car to start via the dealership.
It is having this very strange stutter/vibration when giving it gas, parked or driving. The codes I have gotten are
Present codes- P0301, P0421
Past codes- P0172, P0335
I replaced the CPS yesterday with ease and that did seem to help some, I also checked the plugs and they are still good (they have less than 100 and I'm running the NGK 6510 gapped to 27). I moved coil from cyl 1 to cyl 2 with no misfire issues from cyl 2, so I assume my coils are good.
I don't have a custom tune, I'm running the Cobb stage 1 + SF 93 tune ATM till I can purchase a custom one, but unless my instinctual compass is way, I don't think that would do it. I did try putting the Cobb OEM tune on the car and it didn't change anything other my AFR's kind of being all over the place.
Normally, my next though would be an injector is sticking open or the like, or bad O2. But can this style of fuel system still have a stuck open injector ?
Any ideas or suggestions will be greatly appreciated.
ok, will do.
I forgot to add, but I replaced it along with most of the fuel system. I.E. fuel pump internals, CS fuel line, oem injectors, and pressure relief with an oem one.
Ok, I was finally able to record and get some more logs. Listed below is basically a collection of what I could get with detail.
https://www.revisionsrus.com/logs/2283
cold start and idle
https://www.revisionsrus.com/logs/2285
another start and idle, cold
https://www.revisionsrus.com/logs/2287
doing the stutter while driving
https://www.revisionsrus.com/logs/2288
after drive home from work idle in drive way, running temp
https://www.revisionsrus.com/logs/2289
another log of stutter
https://www.revisionsrus.com/logs/2290
https://www.revisionsrus.com/logs/2291
https://www.revisionsrus.com/logs/2292
and another log of the stutter
Also as an update, I have replaced my coils with brand new ones, I also changed the spark plugs to oem heat range to see if that made a difference, and I bought a new maf today. Haven't put it in yet so these logs are still with a current set up.
Another quick update, I just came back in from car after checking something and when I turned the car(not start) my fuel psi was reading 26/48.
So I'm assuming something is leaking, or not reading correctly ?
I am seeing constant knock in your logs. This will pull timing and cause all sorts of other issues. This could be bad gas, a leaking injector seal, bad sensor "electrical" or an actual physical issue with the engine. I would try and sort out the cause of this before you do much more driving. What are you using to log this?
My AP. my friend and fellow gear head was looking over my logs and we both noticed the knock. Hopefully next week I can get a compression test done to eliminate that as an issue.
This morning I replaced the MAF and the Cam position. When I went to start the car it fired on the first try, which is great progress because before it would take 3-4 before it would start. I'm going to replace the injectors, again, with new oem ones. The ones that are in the car are supposed to be ultra sonic cleaned and flow tested, but I'm starting to believe they are cheap Chinese knock offs and none of that has been done. They don't have fomoco anywhere on the injector and at first I though that was just from the cleaning.
