Jaris Greenie N00B Member Nov 6, 2018 #1 Is genwon and genpu coilovers/aftermarket suspension interchangeable? Do the bolts/holes line up the same? For further clarification, would I be able to take suspension from a genpu and put it on a genwon and vice versa (obvi)? Sent from my iPhone using Tapatalk
Mauro_Penguin Punk in Drublic. #BlackLivesMatter Motorhead Nov 7, 2018 #2 The front yes. The rear no. Gen1 onto Gen2 is ok, Gen2 onto Gen1 wont work because of the flange strap that hugs the shock bolt. If you want to measure it yourself and see go ahead, you could always grind down the lower shock mount too.
Raider Administraider Administrator Nov 10, 2018 #3 Regular struts pu to won you will need washers, I think on back. Don't slap Racelands on there Jaris.
