macdiesel
I got in on the group buy in 2018 and installed shortly after receiving. Out of the box I was really surprised at how light it is. I have the CS front bar and it’s considerably heavier so I was expecting a beefy bar. Not the case, had to throw it on the scale. 920grams. Not only is it light, but it’s light and tight. Install is pretty easy. Position jack stands so you can fit traction bar. Undo 2 bolts, reinstall and boom. You have a traction bar installed. The TB rear bar really tightens the rear end, more so than a rear sway bar. At least to me. It’s even more pronounced whilst doing some wintercross. I had to adjust rear pressures accordingly when autocrossing or attending hpde’s. Overall, super impressed with the product. Definitely recommend it.
