Techna-Fit brake lines
Sleepin6
Silver Member
A8742D9D-BBCE-43D8-8C2D-AE552F9655AD.png Just ordered these for a great price. Will let you know if there quality’s changed when i install them. Not many companies out there anymore that make lines for this car.
I have technafit lines on my gen2. They worked fine. Fitment was ok.
I bought them from RPM like 4 years ago.
Trying out stop tech this go around.
Cool...I’ve heard mixed reviews for the 6 but messaged Stoptech and they confirmed they don’t make them specifically for the ms6 unfortunately.
I had to loosen and re-tighten the front lines a couple of times because of the way the shock mount was positioned. The lines were basically twisted.
If you find the same issue with yours, hit the shock fitting on the brake line with a bit of soapy water and turn it as needed. Then just dry it all off when you're done.
Will let you guys know how i make out. Just arrived today and don’t look to bad as far as quality control goes. Will see...
Installed them today and it went well. I had to tap the front ones on the bracket for the hard line but other then that no problems. Still have to bleed but have other problems to tend to first. Story of an ms6 owner!
I can attest to them being a nice upgrade, even for guys that choose to stay mostly stock.
They take the squish out of the initial brake bite, and give you a nice linear brake feel.
Update on brake feel and performance is that they were worth the monies spent and stop better then stock rubber lines obviously. Hope this helps with anyones purchase in the future.
