Here is a comprehensive list of all suspension systems and components available for the MS3. Please if you would like something added here that I have missed let me know.
SPRINGS
Manufacturer: CorkSport MS3 Lowering Spring Set
Drop front: 1.1"
Drop Rear: 1.2"
Spring rate front: 3.5k
Spring rate rear: 4.5k
Part Number: axl-3-289-10
Price: $279.99
Further Info:
- Crafted from high tensile strength spring steel for long lasting quality and performance
- OEM finish to ensure lasting durability and rust protection
- Average 25% increased spring rate over stock spring rate
- Backed by Corksport limited two-year warranty
- CorkSport Service and Support: Receive full color installation instructions, all of the needed installation hardware, and knowledgeable telephone installation support.
Manufacturer: Eibach Pro-Kit Performance Springs
2007-2009 MS3 (Per Manufacturer)
Drop front: 0.8"
Drop rear: 0.7"
Spring rate front: Not listed
Spring rate rear: Not listed
Part Number: 5549.140
Price: $350.00
or
2010-2013 MS3 (Per Manufacturer)
Drop front: 1.0"
Drop Rear: 0.6"
Part Number: 5554.140
Price: $350.00
Further Info:
- High Performance Handling and Aggressive Good Looks
- Lower Center of Gravity
- Stop Quicker Corner Faster
- Progressive Spring Design for Excellent Ride Quality
- Million-Mile Warranty
Manufacturer: H&R Sport Spring
Drop front: 1.3"
Drop Rear: 1.2"
Part Number: 51643-2
Price: $329.00
or
Drop front: 1.3"
Drop Rear: 1.2"
Part Number: 52603
Price: $349.00
Further Info:
H&R only manufactures springs of the best quality. The strength, resiliency, and durability prevent them from sagging or setting. All H&R springs are made of a special steel structure to provide the ultimate quality and performance spring and shot peened to increase life of the spring by over 200%. Every spring is tested and cleared before being packaged and sent out from Germany. Reduced body roll and improved handling is to be expected.
H&R designs all Sport Springs to provide excellent ride quality while still allowing the drop on the vehicle between 1.5” and 1.8” on average. Wheel well gap is reduced for a much cleaner, aggressive stance. Center of gravity will drop allowing less body roll and improving the car’s ability to handle. Even better aerodynamics is experienced at higher speeds due to the car’s lower relation to the ground. This is H&R’s best selling set of lowering springs.
Manufacturer: Tein S.Tech Springs MS3 2007-2009 (per manufacturer)
Drop front: 1.0"
Drop Rear: 0.6"
Spring rate front: 2.9K
Spring rate rear: 4.3K
Part Number: SKM80-AUB00
Price: $292.00
Further Info:
• Chrome Vanadium SAE9254V Construction
• Progressive Spring Rate Design
• Includes Silencer Rubber on certain applications
• Green Powder Coat Finish
• Developed to be used in conjunction with OEM or OEM replacement dampers
• 1-year Manufacturers Defect and Sag Warranty
Covers over 5mm sag, breakage, deformity, and noise.
Does not cover powder coat finish and rusting.
Manufacturer: Swift Sport Springs Spec-R MS3 2007-2013
Drop front: 1.2"
Drop Rear: 1.1"
Spring rate front: Not Listed
Part Number: 4Z906R
Price: $319.00
Further Info:
Swift made Sport Springs Spec-R is made for true track racing enthusiasts that wants to take their vehicle to the next level.
Sport Springs Spec-R is engineered with 2 main characteristics.
1 Redesign lowering ride height to maximize the suspension performance allowing the vehicle to fully absorb road condition for maximum traction.
2 Increase in spring rate to further enhance cornering speed through entry & exit. The increase in spring rate is based on the vehicle factory stock valving settings. Sport Springs Spec-R is increase to the optimal rate that the stock shocks can handle. Higher performance shocks are not required, but recommended.
Spec R springs are wound with the same engineering as our sports springs. With the exception of stiffer rates and slight change in ride height; you can expect the same characteristics as our sports springs.
Manufacturer: Tanabe Sustec NF210 Lower Springs MS3 2010-2013
Drop front: 1.3"
Drop Rear: 1.1"
Spring rate front: 3.3K
Spring rate rear: 3.3K
Part Number: TNF154
Price: $304.00
Further Info:
Tanabe NF210 Supreme Ride Comfort
The NF210 coil spring features a tasteful drop, and produces the best overall ride quality and comfort for a performance lowering spring. The lowered stance of the NF210 gives the car an elegant pose, while the spring rates, which are only slightly raised (up to 5% over stock) retain factory ride quality settings.
This coil spring is extremely popular with luxury tuned vehicles, as well as those with larger diameter wheels that want to eliminate fender gap, but maintain excellent driveability while reducing the risk of damage to wheels that is associated with stiffer suspensions.
For those who demand the best comfort from a lowering spring
All of our coil springs feature SUSTEC 210 Technology. Sustec 210 Technology is a series of manufacturing methods developed to create a stronger, thinner, and lighter spring using only high tensile steel, without adding additional elements that could affect quality, durability, or price.
"210" stands for 2100n/m of tensile strength, which is the highest strength ever acheived in a coil spring. The Tanabe Shiga factory in Japan is home to some of the most advanced, unique coil spring machines and processes in the world!
SPRINGS
Drop front: 1.1"
Drop Rear: 1.2"
Price: $279.99
Further Info:
Drop front: 0.8"
Drop rear: 0.7"
Price: $350.00
or
Drop front: 1.0"
Drop Rear: 0.6"
Price: $350.00
Further Info:
Drop front: 1.3"
Drop Rear: 1.2"
Price: $329.00
or
Drop front: 1.3"
Drop Rear: 1.2"
Part Number: 52603
Price: $349.00
Further Info:
Drop front: 1.0"
Drop Rear: 0.6"
Price: $292.00
Further Info:
Drop front: 1.2"
Drop Rear: 1.1"
Part Number: 4Z906R
Price: $319.00
Further Info:
Drop front: 1.3"
Drop Rear: 1.1"
Part Number: TNF154
Price: $304.00
Further Info:
