Got into a front end accident a week or so ago, other guy didnt have insurance so stuck trying to fix it myself, got a front clip from someone and new headlights etc (whatever was broken). got that all installed today and have been having a crank no start, i believe i have narrowed it down to something to do with the throttle body. it was still running after the accident but had a dead gas pedal, so i was pretty sure it would run fine, about 2 days ago i started it up to make sure it runs, it did start but ran rough and i quickly shut it off because the whole front end was off the car, i got more into it and saw the throttle body was unplugged, i tried hooking it back up after i had gotten everything else installed into the car and now a crank no start. ran codes i cant remember exactly but something like throttle position circuit high on sensor a and low sensor b and a throttle actuator code. got a throttle body off my old engine and installed it, cleared codes and still crank no start but now no codes. the video is the throttle body when koeo and you can hear me repeatedly pressing the gas pedal with no result. i tested the wires from the throttle body to pcm for continuity as it says in the shop manual and all tested good. any help is appreciated
